Old 11-01-2005, 01:15 PM
I just checked the intersense site, and we are using the latest version of their SDK.
I found the following information in their manual.
TCP SUPPORT
Windows and Irix versions support communication to InterSense
tracking devices over TCP/IP. To use this feature you must
define the connection string in the isports.ini file in following
form: PortX = IP:Port. In the included sample isports.ini file
you will see it as Port3 = 192.168.1.44:5005
Have you tried this? It seems as though all you need to do is create a file called isports.ini and place it in the [Vizard25]/bin directoy. Then add the IP address and port number of the IS-900. Let me know if this works so we can document it.
