Old 10-31-2016, 04:19 PM
The vizconnect configuration file I attached before can be modified to move the hand in/out using the Xbox controller without manually changing the code. Run the config and go to the advanced menu. In the Inputs tab add the Xbox controller. In the Events tab, press the mapping button for each of the events. Then change the input from keyboard to xbox controller and assign the button that will trigger the event.
