So I take it that Vizard is not embedded in your app? Are you simply removing the border around the window and overlaying it on your application? If this is the case then Vizard won't be able to support what you are needing. Vizard can only create one rendering window at a time.
If you were embedding Vizard into your app then you could overlay your GUI controls over the rendering window. This way you could create subwindows and have it look like there are multple windows that are rendering.
