Old 10-25-2016, 07:01 AM
bbb bbb is offline
1) Thanks for your solution, it helped me achieve my goal as much as possible without eye tracking. I created a shape with vizshape (my objects are static and created in Sketchup so i had to create a shape in the vizard script) while using the position of the region of interest i want to know if people are looking at from the inspector, such that it reports me when people are looking at the 3D shape while using the pickRect.
2) I didn't understand how to correctly use your solution to achieve my second goal, which is to get the correlation between position and orientation. I read about the vizmat module but it seems that the methods relay on previous data such as points, positions, vectors and i don't have previous data that can help. I would appreciate if you can explain furthermore.
Thanks.
