Old 10-19-2016, 05:12 PM
I try to use viz.mainview.pickrect as you suggested but the problem is that it gives me nodes that doesn't mean anything to me like viz.vizchild(18). My question is: if i will change my nodes names in the inspector to meaningful names such as sqaure for square object it will give me meaningful names?
You can check the nodes returned by the pickRect command against the node names defined in the script:
Press the spacebar to call the pickRect command
import vizinfo
import vizshape
vizinfo.InfoPanel()
#Define pickRect coordinates
LEFT = 0.4
BOTTOM = 0.4
RIGHT = 0.6
TOP = 0.6
viz.move([0,0,-1])
pyramid = vizshape.addPyramid(base=(0.2,0.2),height=0.2,pos=[-0.5,1.7,1],alpha=0.7)
torus = vizshape.addTorus(radius=0.1,tubeRadius=0.015,axis=vizshape.AXIS_X, pos=[0,1.7,1])
box = vizshape.addCube(size=0.1, pos=[0.5,1.7,1],alpha=0.8)
pyramid.texture(viz.addTexture('images/tile_slate.jpg'))
torus.texture(viz.addTexture('images/tile_wood.jpg'))
# Visualize the area used by the pick operation
viz.startLayer(viz.LINE_LOOP)
viz.vertex([LEFT, BOTTOM, 0])
viz.vertex([LEFT, TOP, 0])
viz.vertex([RIGHT, TOP, 0])
viz.vertex([RIGHT, BOTTOM, 0])
rectangle = viz.endLayer(parent=viz.SCREEN)
rectangle.alpha(.8)
def pickNodes():
	# Get all nodes within the rectangle
	picked = viz.MainWindow.pickRect([LEFT,BOTTOM,RIGHT,TOP])
	for node in picked:
		if node == pyramid:
			print 'pyramid picked'
		elif node == torus:
			print 'torus picked'
		elif node == box:
			print 'box picked'
vizact.onkeydown(' ',pickNodes)
