Old 09-14-2016, 08:46 AM
tokola tokola is offline
Jeff, both models are viewed with None Multisamples, although changing this value has no effect whatsoever.
Also, there's no Effects option in the OSG exporter. Do you mean somewhere in 3DS?
I sought advice from a colleague and he figured out a way playing with smoothing groups, but I'm not sure this is the way to go, as I have to edit every model I am re-exporting. I am sure it should be something with the exporter, unless Autodesk did some change between versions (12 to 15).
Any ideas?
