Hi Jeff,
I wanted to note that the below:
					Originally Posted by willpower2727  None of the options stop rendering or hide it or whatever on the hmd.
	Code: viz.MainWindow.visible(False) Works at hiding the mirrored window on my PC's monitor but the scene is still being rendered on the HMD. |
 Is also a symptom of not having access to the screen on the HMD through vizard. It could well be the same underlying problem as getting resolution of HMD, etc. all viz.MainWindow operations are for the window on the desktop, not the HMD screen.
