Old 08-30-2016, 07:27 AM
tokola tokola is offline
The oil_pump.osgb is the original exported model. I just chose to save the textures as images to keep the file sizes low. I am sure this shouldn't affect the command. Also, I slightly altered the scenegraph of the blue_tanks model in my attempt to make the command work. I basically removed the 'OilDrop' node. You can Save as... yourself from the original to maintain the original structure.
If you believe the textures might affect anything during saving a copy, I uploaded them as a zip file (ref #1634470).
