Jeff,
sorry it wasn't clear, but as I said in my original post I could NOT attach the problematic model created (save as) from the Vizard Inspector. The zipped model is more than 1MB, which exceeds the forum's limitation. I've tried adding the model by itself as well and the problem persists. Something happened during the saving process and the shared_material command does not work.
Let me know if I can send it some other way. Also, I'm not sure if the increase in size is normal (the 703KB file became 5.7MB as soon as I saved it with the Inspector).
Thanks!
