Old 08-03-2016, 04:09 AM
rajnishv rajnishv is offline
Smile Regarding Vizard+ARTSmart Track
Hi Jeff,
Than you for ur reply for ,my last post.
This is also related to last post.
As told by you i have used the "powerwall co-ordinates" as my display and i managed to get orientation and feeling correctly with the ART SmatTrack Camera(as i used to get using World viz camera)when i m orienting in the environment room in the setup.
Problem:-
My head tracker in working proper ,but i have also attached handTracker in the the trackers options in the avatar animator section.
I should get the hand tracker glove to be visible in the display,but it is not visible.
But i m not able to get the HandTracker(Hand Glove not visible) in the display when i have taken "powerwall co-ordinates" as a siplay.
Also pls c to my question and request you to clarify jeff:
1)What happen if i select only "powerwall" instead of "powerwall co-ordinates"?
2)What is "standard" display refers to in vizconnect and does powerwall refers to both "powerwall' and "powerwall coordinates"
I have also attached my "vizconnect_config.py" file in the post.
Pls also see to that.
Also pls explain me the last two lines of your code you posted in reply in some words,as i am not able to get,Pls jeff.
Your code:
headtracker.swapPos([1,2,-3])
headtracker.swapQuat([-1,-2,3,4])
#----------------------------------End--------------------------------#
Pls assist me jeff.
Waiting for ur reply.
Thanx&Regards
Mr.Rajnish Vishwakarma
Mobile,AR,VR
Xenium Digital Pvt ltd,Mumbai
