Old 08-02-2016, 05:52 AM
When things get more complicated I need helper functions, but I suspect these are not supported to work with vizard's effects framework?
I'll check with a developer. Do you need a separate function or can you include the operations directly in the shader code? In the last example on the Example Effects page a number of operations are applied in sequence. Perhaps you can achieve the same result this way. What is the effect you are trying to create?
