Old 08-01-2016, 10:44 PM
Take a look at the following example. This is a modified version of renderNodeSimple.py with a render node texture on a quad fixed to the screen:
This script demonstrates how to use render nodes to create a virtual video camera.
Press spacebar to toggle the camera between panning and following the avatar.
Use the mouse and WASD keys to navigate around the room.
import vizcam
viz.fov(60)
import vizinfo
vizinfo.InfoPanel(align=viz.ALIGN_LEFT_BOTTOM)
# Use keyboard/mouse camera
cam = vizcam.WalkNavigate()
viz.cam.setHandler(cam)
# Add environment
model = viz.add('pit.osgb')
# Create render texture for camera video feed
video = viz.addRenderTexture()
# Create render node for camera
cam = viz.addRenderNode(size=(1280,720))
# Do not inherit view/projection settings from main window
cam.setInheritView(False)
# Set FOV for video camera
cam.setFov(60.0,1280/720.0,0.1,1000.0)
# Render to video feed texture
cam.setRenderTexture(video)
# Only render once per frame, in case stereo is enabled
cam.setRenderLimit(viz.RENDER_LIMIT_FRAME)
quad = viz.addTexQuad(pos=[1,0.6,2])
quad.setReferenceFrame(viz.RF_VIEW)
quad.texture(video)
quad.drawOrder(100)
quad.disable(viz.DEPTH_TEST)
quad.renderToAllRenderNodesExcept([cam])
# Don't render to texture if screen isn't visible (optimization)
cam.renderOnlyIfNodeVisible([quad])
# Add avatar walking around in circles
avatar = viz.addAvatar('vcc_male2.cfg')
WalkSequence = vizact.sequence(
	 vizact.walkTo((0,0,5))
	,vizact.walkTo((5,0,0))
	,vizact.walkTo((0,0,-5))
	,vizact.walkTo((-5,0,0))
	,viz.FOREVER
avatar.runAction(WalkSequence)
# Create attachment point for panning camera
pan_camera = viz.addGroup()
PanEulers = (100,45,0), (170,45,0)
pan_camera.setPosition([-10.94835, 11.09378, 13.61334])
pan_camera.setEuler(PanEulers[0])
PanAction = vizact.sequence(
	 vizact.spinTo(euler=PanEulers[1],speed=5)
	,vizact.spinTo(euler=PanEulers[0],speed=5)
	,viz.FOREVER
pan_camera.runAction(PanAction)
# Create attachment point for following avatar
avatar_camera = viz.link(avatar,viz.NullLinkable)
avatar_camera.preTrans([0,2,-2])
avatar_camera.preEuler([0,10,0])
# Toggle between attachment points with spacebar
camera_link = viz.link(pan_camera,cam)
vizact.onkeydown(' ',camera_link.setSrc,vizact.choice([avatar_camera,pan_camera]))
