					Originally Posted by  Jeff
				If you want to draw a line, create a layer with viz.lines and use the center point of each sphere as a vertex. You can update the vertex positions as the sphere positions change.
 in that way, the system will repeat drawing the line as many as the times of position changes.
is there a way to draw one line and keep updating the position
