What is the size of the model file? When it's loaded on the PC and completely in view what do the render stats show? Press F4 twice to see the render stats with the Vizard script running. I wonder if it has something to do with running a heavier model on that system. Is it possible to disable AutoCal and run the script across all the projectors? If so, does the model show up? Also, try running it on just one or across a few projectors and see if that works.
