Old 07-27-2016, 11:35 AM
Originally Posted by rajnishv View Post
Hi everyone,
If you are using leap motion controller(with leap motion service installed) on the PC,then i have made Vizard to get data from leap motion controller (via leap motion service) and tracked.
The data can also be applied on grabber tool in realtime,with vizconnect grabber tool linking with the data of leapmotion,and then can be oreinted a real hand with a grabber tool.
Pls see to the attached file of the leapmotion controller+Vizard file..
Make sure u have each and every file of SDK and modules in path.
Thank you!!
Thanx & reagrds
Mr.Rajnish Vishwakarma
Software Developer for Mobile,AR,VR
Hi, there is some error comes out "DLL load failed: ֒һսָ֨քģࠩc"
