I think that in versions prior to Vizard 5.3, the mirrored window is automatically rendered in mono when using Oculus direct mode. Starting from Vizard 5.3 and Oculus 0.8, direct mode is required and the mirrored window shows in stereo. This code is a fix for 5.3 and above.
You could try updating both Vizard and Oculus versions. However, as the graphics card does not meet the Oculus recommended specs I'm not sure it will work with more recent Oculus software.
