Old 07-08-2016, 02:13 AM
I'll check in with our developers and get back to you on both questions, orthographic projection and getting Vive specs. I'm not sure there is a Vizard command that will return the resolution and FOV of the Vive. You can use vizconnect or vizard commands to find out if a Vive is connected. Then you could retrieve specs saved to variables or a file. Would that work?
