Old 06-07-2016, 04:21 PM
Ciccio Ciccio is offline
I think I'm getting closer, I created my own extension and from it I load the sensor but I've got a problem:
CExtension.cpp
extern "C" __declspec(dllexport) viz::Extension* CreateVizardExtension(viz::Data &data)
	return new CExtension();
viz::Referenced* CExtension::createSensor(viz::Data &data)
	int command = data.getInt("command");
	return CSensor::Instance();
here is the code of CSensor
CSensor* CSensor::singleton = NULL;
CSensor::CSensor()
	setDataSize(10);
	setVision(false);
	setOculus(true);
	setGyroscope(false);
	setSpeed(1);
	m_data[ISREADY] = VizENum::Off;
void CSensor::command(viz::Data &data)
	switch (data.getInt("command")) {
	default:
		break;
	case ERRORVIZARD:
		setConnected(false);
		break;
	case ACKNOLEDGECOMMAND:
		setAcknoledge(true);
		break;
	case DATACOMMANDR:
		setDataR(data.getFloat("x"),
			data.getFloat("y"),
			data.getFloat("z"));
		break;
	case DATACOMMANDL:
			setDataL(data.getFloat("x"),
				data.getFloat("y"),
			break;
int CSensor::getSourceType() const
	return VIZ_LINK_POS;
CSensor* CSensor::Instance()
	if (singleton == NULL)
		singleton = new CSensor();
	return singleton;
and this is Vizard
ex=viz.add('BMI.Vizard.dle')
self.sensor =  ex.addSensor()
when from Vizard I call ex.addSensor() the program crash with this report
Dump Summary
Dump File:	crashdump.dmp : C:\Users\ASDAP\AppData\Local\CrashRpt\UnsentCrashReports\Vizard (32-bit)_4.09.0016\5ac47f9d-2fa6-4037-b442-22e676c841c9\crashdump.dmp
Last Write Time:	07/06/2016 19:11:40
Process Name:	winviz.exe : C:\Program Files (x86)\WorldViz\Vizard4\bin\winviz.exe
Process Architecture:	x86
Exception Code:	0xC0000005
Exception Information:	The thread tried to read from or write to a virtual address for which it does not have the appropriate access.
Heap Information:	Not Present
System Information
OS Version:	6.1.7601
CLR Version(s):
Modules
Module Name	Module Path	Module Version
winviz.exe	C:\Program Files (x86)\WorldViz\Vizard4\bin\winviz.exe	4.0.0.0
ntdll.dll	C:\Windows\SysWOW64\ntdll.dll	6.1.7601.23418
kernel32.dll	C:\Windows\SysWOW64\kernel32.dll	6.1.7601.23418
KERNELBASE.dll	C:\Windows\SysWOW64\KERNELBASE.dll	6.1.7601.23418
user32.dll	C:\Windows\SysWOW64\user32.dll	6.1.7601.19061
gdi32.dll	C:\Windows\SysWOW64\gdi32.dll	6.1.7601.23418
lpk.dll	C:\Windows\SysWOW64\lpk.dll	6.1.7601.19146
usp10.dll	C:\Windows\SysWOW64\usp10.dll	1.626.7601.19054
msvcrt.dll	C:\Windows\SysWOW64\msvcrt.dll	7.0.7601.17744
advapi32.dll	C:\Windows\SysWOW64\advapi32.dll	6.1.7601.23418
sechost.dll	C:\Windows\SysWOW64\sechost.dll	6.1.7601.18869
rpcrt4.dll	C:\Windows\SysWOW64\rpcrt4.dll	6.1.7601.23418
sspicli.dll	C:\Windows\SysWOW64\sspicli.dll	6.1.7601.23418
CRYPTBASE.dll	C:\Windows\SysWOW64\CRYPTBASE.dll	6.1.7601.23418
comdlg32.dll	C:\Windows\SysWOW64\comdlg32.dll	6.1.7601.17514
shlwapi.dll	C:\Windows\SysWOW64\shlwapi.dll	6.1.7601.17514
comctl32.dll	C:\Windows\winsxs\x86_microsoft.windows.common-controls_6595b64144ccf1df_6.0.7601.18837_none_41e855142bd5705d\comctl32.dll	6.10.7601.18837
shell32.dll	C:\Windows\SysWOW64\shell32.dll	6.1.7601.19135
imm32.dll	C:\Windows\System32\imm32.dll	6.1.7601.17514
msctf.dll	C:\Windows\SysWOW64\msctf.dll	6.1.7601.18731
wininet.dll	C:\Windows\SysWOW64\wininet.dll	11.0.9600.18315
api-ms-win-downlevel-user32-l1-1-0.dll	C:\Windows\SysWOW64\api-ms-win-downlevel-user32-l1-1-0.dll	6.2.9200.16492
api-ms-win-downlevel-shlwapi-l1-1-0.dll	C:\Windows\SysWOW64\api-ms-win-downlevel-shlwapi-l1-1-0.dll	6.2.9200.16492
api-ms-win-downlevel-version-l1-1-0.dll	C:\Windows\SysWOW64\api-ms-win-downlevel-version-l1-1-0.dll	6.2.9200.16492
version.dll	C:\Windows\System32\version.dll	6.1.7600.16385
api-ms-win-downlevel-normaliz-l1-1-0.dll	C:\Windows\SysWOW64\api-ms-win-downlevel-normaliz-l1-1-0.dll	6.2.9200.16492
normaliz.dll	C:\Windows\SysWOW64\normaliz.dll	6.1.7600.16385
iertutil.dll	C:\Windows\SysWOW64\iertutil.dll	11.0.9600.18315
api-ms-win-downlevel-advapi32-l1-1-0.dll	C:\Windows\SysWOW64\api-ms-win-downlevel-advapi32-l1-1-0.dll	6.2.9200.16492
userenv.dll	C:\Windows\SysWOW64\userenv.dll	6.1.7601.17514
profapi.dll	C:\Windows\SysWOW64\profapi.dll	6.1.7600.16385
setupapi.dll	C:\Windows\SysWOW64\setupapi.dll	6.1.7601.17514
cfgmgr32.dll	C:\Windows\SysWOW64\cfgmgr32.dll	6.1.7601.17621
oleaut32.dll	C:\Windows\SysWOW64\oleaut32.dll	6.1.7601.19144
ole32.dll	C:\Windows\SysWOW64\ole32.dll	6.1.7601.23392
devobj.dll	C:\Windows\SysWOW64\devobj.dll	6.1.7601.17621
clbcatq.dll	C:\Windows\SysWOW64\clbcatq.dll	2001.12.8530.16385
cryptsp.dll	C:\Windows\System32\cryptsp.dll	6.1.7601.18741
rsaenh.dll	C:\Windows\System32\rsaenh.dll	6.1.7600.16385
RpcRtRemote.dll	C:\Windows\System32\RpcRtRemote.dll	6.1.7601.17514
ws2_32.dll	C:\Windows\SysWOW64\ws2_32.dll	6.1.7601.17514
nsi.dll	C:\Windows\SysWOW64\nsi.dll	6.1.7600.16385
inetmib1.dll	C:\Windows\System32\inetmib1.dll	6.1.7601.17514
IPHLPAPI.DLL	C:\Windows\System32\IPHLPAPI.DLL	6.1.7601.17514
winnsi.dll	C:\Windows\System32\winnsi.dll	6.1.7600.16385
snmpapi.dll	C:\Windows\System32\snmpapi.dll	6.1.7600.16385
wsock32.dll	C:\Windows\System32\wsock32.dll	6.1.7600.16385
mswsock.dll	C:\Windows\System32\mswsock.dll	6.1.7601.18254
WSHTCPIP.DLL	C:\Windows\System32\WSHTCPIP.DLL	6.1.7600.16385
viz_python.dll	C:\Program Files (x86)\WorldViz\Vizard4\bin\viz_python.dll	0.0.0.0
vizcore.dll	C:\Program Files (x86)\WorldViz\Vizard4\bin\vizcore.dll	0.0.0.0
opengl32.dll	C:\Windows\System32\opengl32.dll	6.1.7600.16385
glu32.dll	C:\Windows\System32\glu32.dll	6.1.7600.16385
ddraw.dll	C:\Windows\System32\ddraw.dll	6.1.7600.16385
dciman32.dll	C:\Windows\System32\dciman32.dll	6.1.7601.19146
dwmapi.dll	C:\Windows\System32\dwmapi.dll	6.1.7601.18917
osg.dll	C:\Program Files (x86)\WorldViz\Vizard4\bin\osg.dll	2.9.12.72
OpenThreads.dll	C:\Program Files (x86)\WorldViz\Vizard4\bin\OpenThreads.dll	2.5.0.12
msvcr90.dll	C:\Windows\winsxs\x86_microsoft.vc90.crt_1fc8b3b9a1e18e3b_9.0.30729.6161_none_50934f2ebcb7eb57\msvcr90.dll	9.0.30729.6161
msvcp90.dll	C:\Windows\winsxs\x86_microsoft.vc90.crt_1fc8b3b9a1e18e3b_9.0.30729.6161_none_50934f2ebcb7eb57\msvcp90.dll	9.0.30729.6161
osgDB.dll	C:\Program Files (x86)\WorldViz\Vizard4\bin\osgDB.dll	2.9.12.72
osgUtil.dll	C:\Program Files (x86)\WorldViz\Vizard4\bin\osgUtil.dll	2.9.12.72
zlib1.dll	C:\Program Files (x86)\WorldViz\Vizard4\bin\zlib1.dll	1.2.5.0
osgText.dll	C:\Program Files (x86)\WorldViz\Vizard4\bin\osgText.dll	2.9.12.72
osgParticle.dll	C:\Program Files (x86)\WorldViz\Vizard4\bin\osgParticle.dll	2.9.12.72
quartz.dll	C:\Windows\System32\quartz.dll	6.6.7601.19091
winmm.dll	C:\Windows\System32\winmm.dll	6.1.7601.17514
psapi.dll	C:\Windows\SysWOW64\psapi.dll	6.1.7600.16385
python27.dll	C:\Program Files (x86)\WorldViz\Vizard4\bin\python27.dll	2.7.2150.1013
CrashRpt1300.dll	C:\Program Files (x86)\WorldViz\Vizard4\bin\CrashRpt1300.dll	1.3.0.0
uxtheme.dll	C:\Windows\System32\uxtheme.dll	6.1.7600.16385
wintrust.dll	C:\Windows\SysWOW64\wintrust.dll	6.1.7601.18839
crypt32.dll	C:\Windows\SysWOW64\crypt32.dll	6.1.7601.18839
msasn1.dll	C:\Windows\SysWOW64\msasn1.dll	6.1.7601.17514
_hashlib.pyd	C:\Program Files (x86)\WorldViz\Vizard4\bin\DLLs\_hashlib.pyd	0.0.0.0
transform.pyd	C:\Program Files (x86)\WorldViz\Vizard4\bin\DLLs\transform.pyd	0.0.0.0
_ctypes.pyd	C:\Program Files (x86)\WorldViz\Vizard4\bin\DLLs\_ctypes.pyd	0.0.0.0
BMI.Vizard.dle	C:\Users\ASDAP\Documents\Francesco\BMI v3.0\Debug\Viz\BMI.Vizard.dle	0.0.0.0
msvcp140.dll	C:\Windows\System32\msvcp140.dll	14.0.23918.0
VCRUNTIME140.dll	C:\Windows\System32\VCRUNTIME140.dll	14.0.23918.0
api-ms-win-crt-runtime-l1-1-0.dll	C:\Windows\System32\api-ms-win-crt-runtime-l1-1-0.dll	10.0.10586.9
ucrtbase.dll	C:\Windows\System32\ucrtbase.dll	10.0.10586.9
api-ms-win-core-timezone-l1-1-0.dll	C:\Windows\System32\api-ms-win-core-timezone-l1-1-0.dll	10.0.10586.9
api-ms-win-core-file-l2-1-0.dll	C:\Windows\System32\api-ms-win-core-file-l2-1-0.dll	10.0.10586.9
api-ms-win-core-localization-l1-2-0.dll	C:\Windows\System32\api-ms-win-core-localization-l1-2-0.dll	10.0.10586.9
api-ms-win-core-synch-l1-2-0.dll	C:\Windows\System32\api-ms-win-core-synch-l1-2-0.dll	10.0.10586.9
api-ms-win-core-processthreads-l1-1-1.dll	C:\Windows\System32\api-ms-win-core-processthreads-l1-1-1.dll	10.0.10586.9
api-ms-win-core-file-l1-2-0.dll	C:\Windows\System32\api-ms-win-core-file-l1-2-0.dll	10.0.10586.9
api-ms-win-crt-string-l1-1-0.dll	C:\Windows\System32\api-ms-win-crt-string-l1-1-0.dll	10.0.10586.9
api-ms-win-crt-heap-l1-1-0.dll	C:\Windows\System32\api-ms-win-crt-heap-l1-1-0.dll	10.0.10586.9
api-ms-win-crt-stdio-l1-1-0.dll	C:\Windows\System32\api-ms-win-crt-stdio-l1-1-0.dll	10.0.10586.9
api-ms-win-crt-convert-l1-1-0.dll	C:\Windows\System32\api-ms-win-crt-convert-l1-1-0.dll	10.0.10586.9
api-ms-win-crt-locale-l1-1-0.dll	C:\Windows\System32\api-ms-win-crt-locale-l1-1-0.dll	10.0.10586.9
api-ms-win-crt-math-l1-1-0.dll	C:\Windows\System32\api-ms-win-crt-math-l1-1-0.dll	10.0.10586.9
api-ms-win-crt-multibyte-l1-1-0.dll	C:\Windows\System32\api-ms-win-crt-multibyte-l1-1-0.dll	10.0.10586.9
api-ms-win-crt-time-l1-1-0.dll	C:\Windows\System32\api-ms-win-crt-time-l1-1-0.dll	10.0.10586.9
api-ms-win-crt-filesystem-l1-1-0.dll	C:\Windows\System32\api-ms-win-crt-filesystem-l1-1-0.dll	10.0.10586.9
api-ms-win-crt-environment-l1-1-0.dll	C:\Windows\System32\api-ms-win-crt-environment-l1-1-0.dll	10.0.10586.9
api-ms-win-crt-utility-l1-1-0.dll	C:\Windows\System32\api-ms-win-crt-utility-l1-1-0.dll	10.0.10586.9
apphelp.dll	C:\Windows\System32\apphelp.dll	6.1.7601.19050
any idea?
