Old 05-10-2016, 12:35 PM
JB_HP_Viz JB_HP_Viz is offline
Jeff,
I think I have the correct settings now by defining four windows
#Define windows
leftWindow = viz.addWindow()
bottomWindow = viz.addWindow()
rightWindow = viz.addWindow()
frontWindow = viz.addWindow()
and then for each client in the cluster.MaskedContext I setup to split the display in two and then display in Fullscreen so each projector
will receive the correct output from the computer. On CLIENT2 I get a subwindow in the top right corner. Other than that problem everything
displays correctly. any idea why I would get the sub-window?
Here is the code I used:
import vizcave
import viztracker
# Declare constants defining the CAVE dimensions
W = 3.048       # 10 feet wide
H = 2.286       # 7.5 feet tall
D = 3.048       # 10 feet deep
W2 = W/2.0
C0 = -W2,H,0     # Front  Wall: C1,C2,C5,C6
C1 = -W2,H,D     # Left   Wall: C0,C1,C4,C5
C2 = W2,H,D      # Right  Wall: C2,C3,C6,C7
C3 = W2,H,0
C4 = -W2,0,0
C5 = -W2,0,D
C6 = W2,0,D
C7 = W2,0,0
#Create front wall
FrontWall = vizcave.Wall(   upperLeft=C1,
                             upperRight=C2,
                             lowerLeft=C5,
                             lowerRight=C6,
                             name='Front Wall' )
#Create left wall
LeftWall  = vizcave.Wall(   upperLeft=C0,
                             upperRight=C1,
                             lowerLeft=C4,
                             lowerRight=C5,
                             name='Left Wall' )
#Create right wall
RightWall = vizcave.Wall(   upperLeft=C2,
                             upperRight=C3,
                             lowerLeft=C6,
                             lowerRight=C7,
                             name='Right Wall' )
#Create bottom wall
BottomWall = vizcave.Wall(  upperLeft=C5,
                             upperRight=C6,
                             lowerLeft=C4,
                             lowerRight=C7,
                             name='Bottom Wall' )
#Initialize graphics window
#Create cave object
cave = vizcave.Cave()
#Define windows
#Add each wall, make sure that they are ordered in the cluster software correctly to match this ordering
cave.addWall(BottomWall, mask=viz.CLIENT1, window=bottomWindow)
cave.addWall(FrontWall, mask=viz.CLIENT1, window=frontWindow)
with viz.cluster.MaskedContext(viz.CLIENT1):
	#Size of each window
	WINDOW_SIZE = [1.0/2.0,1.0]
	frontWindow.setSize(WINDOW_SIZE)
	frontWindow.setPosition([1.0/2.0,1])
	bottomWindow.setSize(WINDOW_SIZE)
	bottomWindow.setPosition([0,1])
	viz.window.setFullscreen(True)
cave.addWall(LeftWall, mask=viz.CLIENT2, window=leftWindow)
cave.addWall(RightWall, mask=viz.CLIENT2, window=rightWindow)
with viz.cluster.MaskedContext(viz.CLIENT2):
	rightWindow.setSize(WINDOW_SIZE)
	rightWindow.setPosition([1.0/2.0,1])
	leftWindow.setSize(WINDOW_SIZE)
	leftWindow.setPosition([0,1])
Create tracker object that represents the users head position, specifically the center of the eyes.
The position provided by the head tracker must be in the same reference frame as the cave wall coordinates.
This will normally be a tracking sensor, but for this example we will simulate a head tracker
using the keyboard (WASD keys).
head_tracker = viztracker.Keyboard6DOF()
head_tracker.setPosition (0.0,1.8,0.0)
Pass the head tracker to the cave object so it can automatically update the
view frustums every frame based on the current head position relative to each wall.
cave.setTracker(head_tracker)
Create CaveView object for manipulating the virtual viewpoint.
cave_origin is a node that controls the position of the cave within the virtual world.
For example, if you wanted to simulate the cave user flying through an environment,
you would apply the transformation to the cave_origin node.
cave_origin = vizcave.CaveView(head_tracker)
The cave_origin node is a standard Vizard node that you can apply any position/rotation to.
In this example we will create a keyboard/mouse tracker (using arrow keys) and link it to
the cave_origin node, allowing us to fly the cave user through the virtual environment.
origin_tracker = viztracker.KeyboardMouse6DOF()
origin_link = viz.link(origin_tracker, cave_origin)
#Add gallery environment model
viz.add('gallery.osgb')
