Old 05-10-2016, 01:15 PM
JB_HP_Viz JB_HP_Viz is offline
Setting for Christie Digital Projector Dual Input 3D
I'm trying to determine the correct setting for the 3D Stereo Mode in Vizard for a Christie Digital Projector that has Dual Input 3D capability which enables the display of two discrete 60Hz video channel inputs for high performance 120Hz output.
https://www.christiedigital.com/en-u...opic-projector
The computer I'm testing supports two Christie digital projectors using the Dual Input 3D capability - a Front Wall and a Right Wall
Nvidia Graphic Card Front Wall Projector(graphic ports 1&2 in duplicate mode) and Right Wall Projector(graphic ports 3 &4 duplicate mode)
See attached file nvidia_configuration_for_client_050316.jpg to see how the outputs are configured in Microsoft Windows and Nvidia control panels.
I'm trying to determine in Vizard what is the correct setting to have it display the 3D stereo?
Since two output are being sent out for each projector but they are duplicated and then the projector provides the Active Stereo neither viz.STEREO_HORZ or viz.QUAD_BUFFER work
Thank you
John
