Old 04-22-2016, 09:23 AM
jelly jelly is offline
I am afraid that the problem continues as soon as I introduce further animation paths. I changed the one I had before to get the following: a trial triggers an animation that moves the viewpoint through a maze until a certain point when it wiats for an arrow key. Once a key is pressed it triggers one of two possible animations (going through left or right door). After this, immmediately, the next trial should start.
Problem 1:
This almost happens, only that the second trial starts at the point where the last door was, etc. I tried resetting the animation paths at various points and nothing seems to help.
Problem 2:
For some reason, it the right arrow key seems to not work. This seems to be a problem of the if statement, because even if I replace the arrow key with the space bar, it does not take the "elif" statement...
I would highly appreciate any pointers in the right direction!
import viz															#Needed to generate a world.
import viztask														#Needed to control the experiment structure.
viz.mouse.setVisible(viz.OFF) 										#Stops the mouse appearing on the screen.
viz.mouse.setOverride(viz.ON)										#Stops Vizard navigation using the mouse.
viz.clearcolor(viz.BLACK)
#Set the start position:
startPos = [-6.4,0,-8]
#Load a maze and make it invisible
maze1 = viz.add('Objects/Maze_1.dae')
maze1.visible(viz.OFF)
#Add a sky with an environment map.
env = viz.add(viz.ENVIRONMENT_MAP,'sky.jpg')
dome = viz.add('skydome.dlc')
dome.texture(env)
#Parameters for the viewpoint
view = viz.MainView
view.eyeheight(1.4)
view.setPosition(startPos)
view.collision(viz.ON)
viz.collisionbuffer(.8)
##Animation path
pathMaze1 = viz.addAnimationPath()
#Add control points to the path, along with their time stamp.
pathMaze1.addControlPoint(2, autoRemove = True, pos=startPos,euler=(0,0,0),scale=(2,2,2))
pathMaze1.addControlPoint(4, autoRemove = True, pos=startPos,euler=(90,0,0),scale=(2,2,2))
pathMaze1.addControlPoint(6, autoRemove = True, pos=(0,0,-8),euler=(0,0,0),scale=(2,2,2))
pathMaze1.addControlPoint(8, autoRemove = True, pos=(0,0,5),euler=(0,0,0),scale=(2,2,2))
#Duation of animation path
pathMaze1Duration = pathMaze1.getDuration()
#animation paths for choosing doors
pathDoorLeft = viz.addAnimationPath()
pathDoorLeft.addControlPoint(0, autoRemove = True, pos=(0,0,5),euler=(0,0,0),scale=(2,2,2))
pathDoorLeft.addControlPoint(1, autoRemove = True, pos=(0,0,5),euler=(-10,0,0),scale=(2,2,2))
pathDoorLeft.addControlPoint(2, autoRemove = True, pos=(-1.3,0,10),euler=(-10,0,0),scale=(2,2,2))
pathDoorLeftDuration = pathDoorLeft.getDuration()
pathDoorRight = viz.addAnimationPath()
pathDoorRight.addControlPoint(0, autoRemove = True, pos=(0,0,5),euler=(0,0,0),scale=(2,2,2))
pathDoorRight.addControlPoint(1, autoRemove = True, pos=(0,0,5),euler=(10,0,0),scale=(2,2,2))
pathDoorRight.addControlPoint(2, autoRemove = True, pos=(1.3,0,10),euler=(10,0,0),scale=(2,2,2))
pathDoorRightDuration = pathDoorRight.getDuration()
def chooseDoor():
	yield viztask.waitKeyDown(viz.KEY_LEFT or viz.KEY_RIGHT)
	if viz.key.isDown(viz.KEY_LEFT):
		link = viz.link(pathDoorLeft,view)
		pathDoorLeft.play()
		yield viztask.waitTime(pathDoorLeftDuration)
	elif viz.key.isDown(viz.KEY_RIGHT):
		link = viz.link(pathDoorRight,view)
		pathDoorRight.play()
		yield viztask.waitTime(pathDoorRightDuration)
def animation():
	link = viz.link(pathMaze1,view)
	pathMaze1.play()
	yield viztask.waitTime(pathMaze1Duration)
	#pathMaze1.reset()
def maze1trial():
	print 'new trial'
	pathMaze1.reset()
	pathDoorRight.reset()
	pathDoorLeft.reset()
	print view.getPosition(mode = viz.ABS_PARENT) #starting point of animation just for control purposes
	maze1.visible(viz.ON)
	yield animation()
	print view.getPosition(mode = viz.ABS_PARENT) #ending point of animation just for control purposes
	yield chooseDoor()
def masterFunction():
	for x in range(4):
		yield maze1trial()
viztask.schedule(masterFunction())
