Old 04-22-2016, 09:23 AM
Vaquero Vaquero is offline
Hey Jeff!
Could you please explain the process for the Enterprise edition in more detail? I'm currently trying to use Vizconnect to use the optical heading plugin, but I haven't yet figured out how to correctly display the mainview on both monitors of the NVisor ST50 HMD (stereo, of course).
How do I run a local cluster? I can't seem to start multiple instances of Vizard, and I can only run either the Cluster Master or the Cluster client at the same time in the same instance. Else I get this warning:
Vizard Cluster Master cannot run while Vizard Cluster Client is running.
Please shutdown Vizard Cluster Client first.
