Old 04-15-2016, 02:14 AM
It's fine if the position markers are not in the same line as the inertia cube. The orientation in terms of pitch and roll does need to be aligned though. You can perform a mounting offset in Vizconnect if the orientation sensor is not likely to be aligned with the user's head.
