Old 03-29-2016, 11:41 PM
If you have two position trackers fixed to the HMD on the left and right you can use vizconnect's optical heading tracker to correct yaw drift. In vizconnect, first add the two position trackers and orientation tracker. Then add the optical heading tracker and use this to drive the viewpoint
