Old 03-20-2016, 11:00 PM
prilpi prilpi is offline
Hi Jeff,
VUALA !! It works!!!
Thanks a lot for the help
It keeps me improving every day...
I used the vizconnect file you sent me for the "piazza" and also copy it to the "maze" - both works great.
I didn't need to set the xbox controller mapping for the transport since it was already set (by default? or set by you before ?)
I tried to copy that same vizconnect config and use it with the "pit" but again
there is still a conflict and i cant get it to work (?)
I think its cuz "faller" linked to head_tracker / main view:
# Create tracked faller and link to main view
faller = PitTrackedFaller(head_tracker)
viz.link(faller,viz.MainView)
and vizcam assigned "head_tracker" to keyboard/mouse navigator :
# Simulate head tracker using keyboard/mouse navigator
head_tracker = vizcam.addWalkNavigate()
head_tracker.setPosition([0,1.5,0])
viz.mouse.setVisible(False)
When i disable the code above and import vizconnect -
oculus + controller works fine but..
No falling when i shift the floor..
I really hope you can guide me thru that "pit" faller issue..
(its not a must for me but that is a great way convincing people with VR..)
Next, ill try to run some tests with imported sketchup scenes (oculus + controller) and to get knowing my way with the inspector..
Thanks again for the great help !
I look forward to your response
Ofri
