Old 09-28-2005, 09:38 AM
tobin tobin is offline
Much of what you may be trying to achieve might be best done using "render to texture" features within 3DMax. There, you can perform fancy (otherwise non-realtime) lighting and render the results to a light map which can then be used in Vizard to modulate your scene. I don't have a demo I can easily provide you at the moment but the duck court room is an example of render to texture--all the lighting effect there are generated in 3DMax and baked onto the wall textures. Lights maps are slighly different but same idea.
