Old 09-27-2005, 04:52 PM
I just ran the following script and it works fine on the system here. Can you try it out and let me know if you have problems with it. Also, are you calling the reset() command on the ppt sensors?
ppt1 = viz.add('vizppt.dls')
ppt2 = viz.add('vizppt.dls')
viz.startlayer(viz.LINES)
viz.linewidth(3)
viz.vertexcolor(viz.RED)
viz.vertex(0,0,0)
viz.vertex(0,0,1)
rod = viz.endlayer()
viz.clearcolor(viz.GRAY)
viz.move(0,0,-5)
viz.add('tut_ground.wrl')
def ontimer(num):
	rod.translate(ppt1.get())
	rod.lookat(ppt2.get())
viz.starttimer(0,0,viz.FOREVER)
