Old 02-24-2016, 06:22 PM
Vaquero Vaquero is offline
Exclamation can't load exported Cal3d Avatars from Autodesk Character Generator
Hello! I'm still trying to get any character to work in vizard besides the ones that are delivered with the software. And it fails! Again.
This time I created an avatar with Autodesk's Character Generator. I followed the steps from the help.
Select the root bone, go to export, select Cal3d Skeleton file, set number of influences to 4 (because I want to use hardware skinning anyway), save.
I changed the materials to contain numbers in square brackets and set to Blinn shading model.
Then I selected the meshes in the file that I want to export (there are several resolutions), export as Cal3d Mesh file. Repeat for meshes of other resolutions.
Exported the 1 material that is used.
Created the cfg correctly.
Trying to open the skeleton file in the Inspector throws this message:
Inspector
Failed to load "F:\\Autodesk.CharacterGenerator\Cal3d\ACG_mSkel.csf":
Warning: Could not find plugin to read objects from file "F:\\Autodesk.CharacterGenerator\Cal3d\ACG_mSkel.csf".
So why is following the vizard instructions failing again?
