Old 02-08-2016, 12:25 PM
If the position is good in the piazza but not your own scene, it's likely an issue with the model. Your model may not be exported at the origin in the modeling software or the units may be different than Vizard and the scaling is off. You can look in Inspector to see if the model is offset from the origin and check the model size in meters.
