Old 02-02-2016, 10:35 AM
jelly jelly is offline
Thank you!
Hi Erikvdb!
First of all thank you so much for the prompt and detailed help! It really helps me understand what is happening in the code. Before I saw your reply, I eventually had managed to do this, it sort of seemed to work:
import viztask
import random
sound = viz.addAudio('pip.wav')
def soundloop():
for x in range (10):
yield viztask.waitTime(random.randrange(3,7,1))
pip.play()
soundtask = viztask.schedule(soundloop())
But I can understand how your code if different and better and I will play around with it a bit to see what happens if I change various bits of it.
Again, thank you so very much!
