Old 01-28-2016, 03:27 AM
I'm not sure if there is a way to get the time of the Leap event at a rate faster than the Vizard main loop. How are checking the 3D position? Is this done through Leap Python code or using Vizard commands?
Try the attached example script which uses a Vizard module to get the Cedrus data. This was developed awhile back and I'm not sure it's compatible with the latest protocol. It provides the response time the Cedrus reports.
File Type: zip cedrusExample.zip (803 Bytes, 3975 views)
