Old 01-21-2016, 02:06 AM
The different versions of Vizard are compatible with different versions of the Oculus runtime. If you're running Vizard 5.3 then you'll need to have version 0.8 of the Oculus runtime installed. Verify the Oculus is connected in the Oculus configuration utility before you run Vizard.
