Old 12-22-2015, 10:34 AM
meltaweel meltaweel is offline
Registered User
Hello ,
it's an old topic , but i have the same problem as Adam.
i'm using Vizard 5 and i tried to do this as explained above
"C:\Program Files (x86)\WorldViz\Vizard5\bin\vizard.exe" -publish "C:\Users\USERNAME\Desktop\SETTINGS_FILE.xml”
it doesn't show up with any thing and the exe file doesn't be generated beside the XML file as Jeff said.
and yes when i have published first time from Vizard GUI , it published the exe without any problems and was working fine. and i've used the "publish settings" XML file from the "Finished Building" step.
and i have ensured that the bin file path working fine because when i run
"C:\Program Files (x86)\WorldViz\Vizard5\bin\vizard.exe" this it opens the Vizard IDE successfully !
please help !
