tap tap
Ok, so does anyone have a fix for this yet?
I've stumbled across a work around (I wouldn't go so far as to call it a fix).
I've setup the registry key (see above) for a W8.1 x64 box but the safety warning messag isn't cleared by key presses, *however* if I gently tap the side of the rift unit (as if tapping my temple) then the message is cleared. Bizarre!
I'd be interested to know if this is just for my unit?
A proper fix would be appreciated.
(vizard 5.2 x64 & HMD firmware 2.12 )
