Old 09-19-2005, 02:16 PM
Are you using the built-in head of the avatar or are you adding a vzf head? To clear the morph of a vzf head, you need to call the clear command on the face object of the avatar. If you are using the built-in head then you need to get the jaw bone of the avatar and reset its rotation to the following axis angle rotation [1,0,0,97.35].
However, it should be possible to keep the mouth movement synced. The code for the speak action is located in vizact.py. It currently uses the viz.playsound function to start the sound and doesn't do any resyncing afterwards. Instead of doing this you could add an audio object and periodically check what its current position is and resync the mouth movement with it. When I get some time I will try to add this.
