vizcave coordinates
I am using a 3DMonitor with shutter-glasses and a chinrest to stable the user's head. I use vizcave since I want to apply an asymmetric view frustrum. I would like to set the origin of the coordinate system to the upper left corner of my display (because this is the coordinate system my eye-tracker uses). However, my code does not seem to set the origin to the display corner.
import vizshape
import vizcave
import viztracker
width = 0.60
height = 0.335
distance = 0.70
PowerWall = vizcave.Wall(upperLeft=(0,0,0), upperRight=(width,0,0), lowerLeft=(0,-height,0), lowerRight=(width, -height, 0))
viz.go(viz.QUAD_BUFFER|viz.FULLSCREEN)
cave = vizcave.Cave()
cave.addWall(PowerWall)
head_tracker = viztracker.Keyboard6DOF()
head_tracker.setPosition (width/2, -height/2, -distance)
cave.setTracker(head_tracker)
What am I doing wrong? Could I set the origin to the display corner? If yes, how?
Also, I noticed, that although I used meters to specify the positions, my scaled objects seem to have the wrong size (far smaller). What do I need to consider concerning scale?
Greetings,
Rebekka
