Old 10-01-2015, 02:31 AM
unabhan unabhan is offline
Add "disable health and security warning" to Oculus config util
You'll have to edit the registry open a command window as Administrator
and run RegEdit.exe
If your Windows is 32-bit go to:
HKEY LOCAL MACHINE\Software\Oculus VR, LLC\
If it is 64-bit, go to:
HKEY LOCAL MACHINE\Software\Wow6432Node\Oculus VR,LLC\
then add a new key called LibOVR
to this key add new string called valueHSWToggleEnabled
and set it value to 1.
When you open the Oculus config util and click advanced there will be a new line with the "disable health and security warning" Option.
Good luck
