I just created a test script here that sends tracking data from an intersense to another script. The data is being sent every frame, so 60 times a second. I tried receiving the data on two separate machines, and on both of them the latency for receiving data was around 1 millisecond. These tests were also done on winxp.
Are you sending the data over a local network? Is Windows XP firewall enabled? We've had problems with that before. Are you using Vizard's built-in networking functionality to receive the messages?
