Old 09-09-2015, 03:19 AM
Samuli Samuli is offline
How to get wand tracker?
I've tried to get wand tracker (and later on use its orientation information) using either of the following code snippets:
ppt=viz.add('ppt.dle')
wand = ppt.addWand()
or:
spacez=viz.add('zspace.dle')
wand=spacez.addWandTracker()
but neither works. From the latter I get the following error message:
** ERROR: Failed to initialize zSpace: Runtime Not Found
** ERROR: Failed to create extension sensor with zspace.dle
skydome.dlc
The first code snippet produces following error message:
trying serial 3
Wand: input buffer not flushed
(Make sure port name is valid and it has not been opened by another program)
What is the correct way to get wand tracker?
