Old 09-01-2015, 08:24 PM
jeremy jeremy is offline
Axes indicator sample script
Hello Walter,
Thank you for your post. I like the feature idea
I've gone and put together a sample script, here is the code:
"""Two examples of ways to provide a visual indicator of world
orientation which is always in view. A compass of sorts, effectively
setup as a "Heads-up display" or HUD.
Two options are provided:
The first sets up the HUD as a group node which is linked to the view.
The second sets up a VizGUICanvas object, which is a new feature in
Vizard 5 providing a flat render node designed for displaying GUI
elements or other nodes. (In this example the canvas uses the
"WorldOverlay" render mode).
For both of these examples, the HUD is a node in the world (as opposed
to being in an ortho window, or screen space). While it is possible to
set up a HUD in window or screen space, an advantage to having a HUD
in world space is that rendering can be simplified as there's no
need for special treatment for such aspects as lighting, depth
testing, or stereo.
import vizshape
viz.MainView.setPosition(0.5, 1, -3)
# Set to 1 or 2 as desired
example = 1
if example == 1:
	# Set up a group node to be the HUD.
	# Other geometry will be parented to this node.
	viewGroup = viz.addGroup()
	# Link the HUD to the main view so it's always in view
	viewGroupLink = viz.link(viz.MainView, viewGroup)
	# Shift the HUD a meter in front and down and to the left a bit
	viewGroupLink.preTrans([-0.3, -0.2, 1])
	# Add a small 20x20cm grid to provide a bit of frame of reference
	grid = vizshape.addGrid(size=(0.2, 0.2), step=0.05, parent=viewGroup)
	# Add small (10cm long) axes which will serve as the indicator
	axes = vizshape.addAxes(length=0.1, parent=viewGroup)
if example == 2:
	# Setup a GUI canvas to serve as the HUD
	# One advantage of the GUI canvas is that, as a separate render
	# node, it is always drawn on top. So the HUD won't be occluded
	# when the view gets up close to an object in the scene.
	canvas = viz.addGUICanvas()
	# Define the dimensions of the canvas
	canvasDimensions = [800, 600]  # width, height in (virtual) pixels
	# Canvas field of view will be slightly smaller than the window's
	canvasFOV = viz.MainWindow.getVerticalFOV() - 15
	# Depth of 1m
	canvasDepth = 1  # distance out in front (meters)
	# Set up the canvas render parameters
	canvas.setRenderWorldOverlay(canvasDimensions, canvasFOV, canvasDepth)
	# Because the canvas-space has units of pixels, added nodes must
	# be greatly scaled up to appear acceptably-sized
	canvasUpscale = [100, 100, 100]
	# Add a grid to provide a bit of frame of reference
	grid = vizshape.addGrid(size=(2, 2), step=0.5, scale=canvasUpscale, parent=canvas)
	# Add axes which will serve as the indicator
	# The axes are parented to the canvas, placing them at the origin in
	# canvas-space, which is the lower-left corner of the canvas.
	axes = vizshape.addAxes(scale=canvasUpscale, enable=viz.DEPTH_TEST, parent=canvas)
# Setup a link in orientation between the dojo (world coordinates)
# and the axes (the indicator of world orientation)
link = viz.link(dojo, axes, mask=viz.LINK_ORI)
# Because the axes are linked to the main view, any orientation of the
# main view needs to be negated in order that the axes align properly
# with the world coordinates. Setup a link operator wherein the link
# is post-multiplied with the inverse matrix of the main view.
link.postMultInverseLinkable(viz.MainView)
Please let me know if this is helpful, or if I could provide further assistance. Thank you for using Vizard.
Best,
Jeremy Sarchet
