Hey again, sorry for the delay, I couldn't test your suggestions until today.
- The same problem occurs when I run the vizard example
- I run the HMD in extended mode
- The oculus runtime is version 0.4.4 Rev1
- Just for your information: The same problem occurs also when I use a different monitor...
I haven't changed the driver yet, and I would rather want to avoid that, but if nothing else can solve the problem, then I would try it as a last attempt.
Do you have any further ideas/suggestions?
Best,
Matthias
