Old 07-29-2015, 05:39 AM
mape2k mape2k is offline
One solution would be to avoid linking the sensor and the 3d node.
When you create a sensor, you can specify a 3d node as its source. This way, you can make the 3d node disappear by calling the source of the activated sensor and let it disappear
Below is a small example:
# create ball and sensor
ball = vizshape.addSphere(radius = 10)
ballSensor = vizproximity.Sensor(vizproximity.CircleArea(10),source=ball)
# wait for sensor to be activated, can be a list of sensors
enteredSensor = yield vizproximity.waitEnter(ballSensor)
# get 3d node of ball and let it disappear
ball = enteredSensor.sensor.getSource()
ball._node.visible(viz.OFF)
