				Code generated for Corner Cave with PPT Configuration through VizConnect
			Hi jeff please find the code of ...
 i got the a Preset Configuration Script...and i saved as ..'corner_cave.py' file..instead of 'vizconnect_config.py'..
 The code of 'corner_cave.py' file is attached as a file ...in the doc file.
 The attached  '.doc' file contains the code of ...'corner_cave.py' file..instead of 'vizconnect_config.py'..
 Note :
 'vizconnect_config.py' is same as 'corner_cave.py'
 I have just changed the name..
