Old 06-02-2015, 12:00 PM
vlc vlc is offline
Hi Jeff,
Computer A has the IS900, however I want Computer B to be able to connect to the tracker on the IS900 using VRPN. I know that you mentioned in other posts how to create the stream, but my question is: how do you actually obtain the data from the stream. If Computer A has the VRPN stream running, how would I get that data from the stream using computer B. Does that make sense?
