Old 05-28-2015, 08:02 AM
makinate makinate is offline
Hi Jeff,
Thanks for your help. Unfortunately this did not do the trick.
I downloaded the installer and copied it into the Scripts folder (the same as pip-script.py) and ran Vizard as an administrator but still not luck. Here is my error message when I type "install numpy‑1.9.2+mkl‑cp27‑none‑win_amd64.whl" into the Run Arguments toolbar and run pip-script.py:
** Loading pip-script.py
C:\Program Files\WorldViz\Vizard5\bin\lib\pkgutil.py:186: ImportWarning: Not importing directory 'C:\Program Files\WorldViz\Vizard5\bin\lib\site-packages\collective': missing __init__.py
  file, filename, etc = imp.find_module(subname, path)
C:\Program Files\WorldViz\Vizard5\bin\lib\pkgutil.py:186: ImportWarning: Not importing directory 'C:\Program Files\WorldViz\Vizard5\bin\lib\site-packages\collective\recipe': missing __init__.py
C:\Program Files\WorldViz\Vizard5\bin\lib\pkgutil.py:186: ImportWarning: Not importing directory 'c:\program files\worldviz\vizard5\bin\lib\site-packages\collective': missing __init__.py
C:\Program Files\WorldViz\Vizard5\bin\lib\pkgutil.py:186: ImportWarning: Not importing directory 'C:\Program Files\WorldViz\Vizard5\bin\lib\site-packages\zc': missing __init__.py
Requirement u'numpy\u20111.9.2+mkl\u2011cp27\u2011none\u2011win_amd64.whl' looks like a filename, but the file does not exist
Exception:
  File "C:\Program Files\WorldViz\Vizard5\bin\lib\site-packages\pip\basecommand.py", line 122, in main
    status = self.run(options, args)
  File "C:\Program Files\WorldViz\Vizard5\bin\lib\site-packages\pip\commands\install.py", line 257, in run
    InstallRequirement.from_line(name, None))
  File "C:\Program Files\WorldViz\Vizard5\bin\lib\site-packages\pip\req.py", line 151, in from_line
    link = Link(path_to_url(name))
  File "C:\Program Files\WorldViz\Vizard5\bin\lib\site-packages\pip\download.py", line 323, in path_to_url
    url = '/'.join([urllib.quote(part) for part in filepath])
  File "C:\Program Files\WorldViz\Vizard5\bin\lib\urllib.py", line 1282, in quote
    return ''.join(map(quoter, s))
KeyError: u'\u2011'
Storing debug log for failure in C:\Users\mkinated\pip\pip.log
My first intuition was that I downloaded the wrong file and put it in the wrong folder, but I think I followed your instructions (See screenshot).
https://drive.google.com/file/d/0B5d...ew?usp=sharing
Any idea what went wrong?
