Fading/lightening-Problem and viz.go in module
is there a command to turn off the "fading effect" the further the object is from the view. It is a problem, for the grid mode, as the grid is not very visible about a m from the view as it is not perpendicular to the view but parallel.
I externalized some classes to a seperate module (the balls). The funny thing is, that the original program only works (meaning shows the balls) if I let viz.go at the beginning of the module.
If I omit viz.go in the module it just does not show the ball but I get no error)
Did you get my email on monday?
Johannes
