Jeff,
Thank you for the example using Vizconnect. It worked for connecting to the Zspace display, but I have not been able to get the grabber to work using the Wand like in the example program zspaceExample.py. I have been able to use the grabber with a mouse using Vizconnect without any problems. Seeing if you have any suggestions on how to get the Wand setup correctly like you have in zspaceExample.py and you can grab the different models and move them around.
Thank you
John
