360 panorama walk around
Is it possible to set 360 panorama to be walking environment with Oculus rift? I used to use Oculus.setZoom to fake walking environment, but I cannot replicate the same for DK2 since the function is no longer available in Vizard 5.
Is there any alternative way to achieve the same? I have been using developed application for research (as well as introducing the developed application in research method courses) and unfortunately, the application no longer work the same after migrating to DK2 which is very problematic. I would very much appreciate if you could suggest me any solutions or resolutions with this regards.
Thank you in advance.
