Old 03-27-2015, 03:54 AM
mape2k mape2k is offline
you can do that by defining a function and calling that function repeatedly at a give rate with the vizard <ontimer> function. See my quick example below.
def writeJoystickPosition():
	joyData1 = joy1.getPosition()
        joyData2 = joy2.getPositio()
        here some lines to write it to a file....
logJoystick = vizact.ontimer(0,writeJoystickPosition)	# start the function
If you start ontimer with a 0, it will call the function each frame. You can also put in other values, e.g. 1 would mean every second.
