Old 03-23-2015, 11:03 AM
Goof Goof is offline
Thanks for the help Jeff. The problem still arises when I use images with dimensions in powers of two (to avoid Vizard rescaling the image) and when I use pictures with an aspect ratio of 1 (to avoid scaling on the texture quad).
It seems like the blurriness is caused by the image being scaled somewhere along the line but I cannot figure out where. If it helps any, I'm using Vizard 3.0.
